Im planing on getting ROG Strix X470-F Gaming motherboard. I have cmt 520 case with 4rgb fans that have 6pin connectors, with them i got a cable with 4 6pin ports (for the fans) ,a molex for power and a 4pin to controll rgbs. I know usualy it connects to RGBW but mobo doesnt have RGBW connector. Can i connect the fans to 12vrgb connector wich is usualy for led strips? or some other connector?
Thanks
https://linustechtips.com/topic/993723-rgb-fan-header/
Thanks
Looks like they provide you an adapter for attaching all the fans onto your motherboard for RGB based control.
https://www.tweaktown.com/reviews/8628/fsp-cmt520-rgb-mid-tower-chassis-review/index6.html
fsp-cmt520-rgb-mid-tower-chassis-review_260
https://linustechtips.com/topic/993723-rgb-fan-header/#findComment-11955109
2 minutes ago, CaptainSpeedster said:
yea, but can i connect it to 12vrgb or does it have to be rgbw?
Those are just standard 4 pin RGB fans not RGBW The other pins are for fan power via the molex power adapter cable. In that case you would have no fan speed control only a set speed.
https://linustechtips.com/topic/993723-rgb-fan-header/#findComment-11955123
6 minutes ago, CaptainSpeedster said:
ik, but when i connect them to the adapter there is the 4pin for rgb control ,to what can i connect that 4pin adapter on the mobo? Im ok with them on the 100%, they are actualy really quiet.
It would connect to the motherbaord's analog (4pin) RGB header.
https://linustechtips.com/topic/993723-rgb-fan-header/#findComment-11955143
