On 11/11/2018 at 10:00 AM, WereCat said:
You should have no problems at all streaming using x264 with 8700k, what settings are you using exactly? And what software you use for streaming?
Well I am using OBS with 4500 bitrate x264 with my encoder preset at slower. Plesase help @WereCat
https://linustechtips.com/topic/993564-please-help/#findComment-11960417
Well, there is your issue.
The slower the preset, the more CPU demanding it is but the quality goes higher a bit.
Using "slower" preset is just way too demanding for 1080p60, just stick to "very fast" or "faster" presets.
And for the love of god, dont stream 1080p60 at 4500, thats not even good enough for 1080p30 or 720p60.
https://linustechtips.com/topic/993564-please-help/#findComment-11960449
