Fan Control
Solved by Guest,
6 minutes ago, lucajm said:I am just confused if the normal PWM connector for the RGB Fans also lets me control the fans because there are RGB ports on the Commander Pro. Or are the RGB ports for something else?
There is a pretty good review below that shows them using Corsair RGB fans and a Commander Pro.
https://www.guru3d.com/articles_pages/corsair_commander_pro_review,1.html
