Painting CPU Cooler
Go to solution Solved by TheGamingLanceYT,
not really but will make ur cooler look more sexy tho!!
Im a Aussie gamer on half decent hardware......
desktop
i7 7700k 4.8ghz Msi ProCarbon Z270 gtx 1080 250gb samsung 850 evo 16gb ddr4 3000mhz ram 2tb wd black 1tb wd green
laptop:
Msi gs40
i7 6700hq 16gb ddr4 gtx 970m 128gb ssd 1tb ssd
https://linustechtips.com/topic/992401-painting-cpu-cooler/#findComment-11942763
2 minutes ago, Worstcaster said:
Would painting just the top fin of a cooler black significantly effect its cooling?
in theory, black is actually the best colour in term of transferring heat energy.
but what matters more is the material of paint vs aluminum
https://linustechtips.com/topic/992401-painting-cpu-cooler/#findComment-11942764
On ‎11‎/‎9‎/‎2018 at 5:45 PM, Mugenjynn said:
Black absorbs sunlight ?. Backwards maybe
 Well all light really, which is why it's black, it doesn't reflect much of the color spectrum back off itself.
Overall though, color has nothing to do with how well a fan functions outside of the light absorption factor...and that isn't likely to be significant enough of a factor to really be measurable.
https://linustechtips.com/topic/992401-painting-cpu-cooler/#findComment-11952799
yes it goes backwards too, both heat and light are similar in nature.
On 11/9/2018 at 4:58 AM, Worstcaster said:
Thanks for the replies.  Bus material of paint, do you mean spray vs say acrylic?
most paints on the market is fine, just dont spray too thick
https://linustechtips.com/topic/992401-painting-cpu-cooler/#findComment-11955407
Just don't paint the spot that contacts the CPU and you shouldn't have a massive difference. As Im imagine the cooler will be removed for painting.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/992401-painting-cpu-cooler/#findComment-11955666
