So, because my current GPU (an original (release) R9 380 4GB) has a broken fan I'm planning on buying a new GPU
the problem is that because I'm only 14 - 16 I don't really have that much money I'm gonna try to get save up some money so that at the beginning of 2019 I should have around 600 CAD /  455 USD / 400 EUR
now my question is which GPU would be best suited to my PC and budget
because most people will need this information:
my PC is a "Pandora - Turbo CD 3500+"
here's the spec sheet
(also the GPU schould be easy to install becuase i never installed a GPU before)
CPU: Ryzen 5 1500x @ 3,65 GHz
RAM: 16 - 64 GB DDR4 @ 2133 Mhz (SODIMM)
GPU: R9 380 (4GB) @ 980 Mhz / 1337 Mhz
HDD: 3TB @ 15.000 RPM
SSD: 256 GB @ 3 G/bit
CPU: Ryzen 7 3700x (Stock)                              RAM: 16 GB Samsung ram
GPU: 2080 Super                                                SSD: 256GB Samsung 980 Evo
https://linustechtips.com/topic/991700-best-gpu-for-600-cad/
Oh and the GPU should be 4k and FreeSync ready
https://linustechtips.com/topic/991700-best-gpu-for-600-cad/#findComment-11936256
Just now, DVA said:
Are you ok/feel safe with buying a used card?
If it works with my PC I'm fine with it.
https://linustechtips.com/topic/991700-best-gpu-for-600-cad/#findComment-11936269
Just now, Cigano said:
Vega 64 is your only free sync option for 450-600
Are the Vega GPU's already that cheap? last time I checked they were around 1000-1200€ (1.790 CAD)
https://linustechtips.com/topic/991700-best-gpu-for-600-cad/#findComment-11936277
You're looking at Vega for 4K and FreeSync. Not really any other options.
https://linustechtips.com/topic/991700-best-gpu-for-600-cad/#findComment-11936281
Yup Vega 64 can be found new for around 600 CAD now, or i should say In the US they are selling for 450 US so which is obviously around 600 CAD but maybe availability in Canada is still limited i'm not sure. If that's the case the used market is the way to go.
https://linustechtips.com/topic/991700-best-gpu-for-600-cad/#findComment-11936287
How is $600 not that much money for just a graphics card?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/991700-best-gpu-for-600-cad/#findComment-11936299
600 CAD is around 400 - 430€
that's what most people that are around 16 years old get as pocket money in Germany and some other parts of Europe
https://linustechtips.com/topic/991700-best-gpu-for-600-cad/#findComment-11936313
btw. another question; if I get the Vega 64 could I use it in Crossfire with my R9 380? (they are both AMD Cards)
https://linustechtips.com/topic/991700-best-gpu-for-600-cad/#findComment-11936318
nope, they have to be identical cards (generation wise and chip wise), like Vega 56 and a vega 56, or a r9 380 and a r9 380. and in my opinion, single GPU is always better if you can afford a more expensive one in place of the 2 lesser ones.
but for 4k, id still go higher end Nvidia and just ditch freesync if you would be ok with it.
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
https://linustechtips.com/topic/991700-best-gpu-for-600-cad/#findComment-11936334
now, would it be out of the question to watercool the GPU? it would prevent you needing to buy a new one entirely if you want to avoid getting something new.
RIP
https://linustechtips.com/topic/991700-best-gpu-for-600-cad/#findComment-11936340
Kinda...I'm pretty sure it would be hard to find a water cooler for a GPU that is mounted on the main circuit board
https://linustechtips.com/topic/991700-best-gpu-for-600-cad/#findComment-11936354
I'm gonna be back in an hours so I'm gonna respond a little bit later
https://linustechtips.com/topic/991700-best-gpu-for-600-cad/#findComment-11936402
