Intel Core i5-7400 Quad-Core - 400$ for that??? Where do you live? In what currency you buying?
His list from the text file:
Processor:
Video Card:
GeForce GTX 1050 - 280$
Ram:
16 GB - 270$
SSD:
Samsung 860 Evo 500 GB - 168$
2nd Monitor:
Hannspree HannsG HE195ANB - 140$
Motherboard:
ASUS PRIME H310M-K - 100$
Power Supply:
Coller Master Elite V4 600W - 82$
Cooling:
be quiet! Pure Wings 2 - 14$
TOTAL PRICE:
1454$
22 minutes ago, sheikm11 said:
My PC (By Price).txt  This Is The PC I Want To Build. I Want To Ask If They Will Fit And If I Buy The Parts I Can Build It. Because I Don't Want To Have To Return The Parts. I Have Included The Parts And The Links
My PC (Links).txt
Are you Bulgarian? Bulgarian lev is around 50 euro cents, that would make sense. If not, what's the currency where you live? As for the build I would recommend at least 1050 ti, not regular 1050.Psu is not great either. Get EVGA maybe, 80+ bronze, they are cheap but not bad at all.   Consider ryzen maybe? More bang for buck.
