5 minutes ago, SNIPSNIPE said:
Hey so I was wondering if there are any companies that do custom case designs such as adding a custom paint design to the outside of the case. I wanted to put a album cover as the design so I cannot spray paint it myself sadly. Any suggestions?
Welcome to the Forums!
For custom work depending on the complexity your best bet may be to look for local specialist automotive paint or decal/signage shops. Depending on what kind of work you plan to put on they can either airbrush it directly on the case or use a vinyl design or print.
-Moved to Modding Section-
https://linustechtips.com/topic/991145-custom-case-design/#findComment-11931048
Singularitycomputers does, it would probably cost close to $1k or more though.
https://linustechtips.com/topic/991145-custom-case-design/#findComment-11931122
