GPU not starting F@H
Solved by Spotty,
Finally fixed it. Issue with both 7.5.1 and 7.4.4 seemed to be related to OpenCL. I noticed in GPU-Z the OpenCL box wasn't checked when I was installing the Nvidia display drivers (downloaded from Nvidia website).
- Unplug ethernet cable
- Boot in to safe mode
- Use DDU to uninstall the Intel HD display drivers
- Reboot in to safe mode
- Use DDU to uninstall Nvidia display drivers
- Run Disk Cleanup on C Drive to remove old drivers in the driver repository
- Install Nvidia Display Drivers (399.24) (while in safe mode!)
- Reboot
- Install Folding At Home 7.5.1
- Realise that your ethernet cable was still unplugged and then it fails to download the GPU.txt file and your install is borked.
- Plug in ethernet cable
- Uninstall Folding At Home 7.5.1
- Reinstall Folding At Home 7.5.1 - It will now launch the browser window to allow you to put in your user information and start the folding tasks.
@TheRandomness if you're still having issues with 7.5.1, check GPU-Z to see if OpenCL is checked.
Finally getting those sweet, sweet points.
