I NEED HELP! So I have had my pc for 4 years and had some to none problems with it. When it comes to fps or any kind of studdering as long as I have the games on a reasonable settings I have no problem running them, but now I have fps problems with Destiny 2 that came out of nowhere. I've had the game since it lauched and had zero problems before with it, and now for about a week ago I CANT get 60+ fps anywhere with the lowest settings only in the menu and in Orbit. I've tried cleaning my pc 100% and re-installed it. None that worked
Specs:
GeForce GTX 1050Ti
Intel(R) Core(TM) i5-6500 CPU @3.20Hz
16 GB RAM
On a 144hz monitor (1920x1080)
https://linustechtips.com/topic/990141-low-fps-on-low-settings/
21 minutes ago, MultiSkitzo said:
I've reset my pc 2 times and still had the same problem.
If you reset your computer and download the drivers then you would be getting the newest drivers. If the new drivers are the issue you would have to use an older driver to fix it.
https://linustechtips.com/topic/990141-low-fps-on-low-settings/#findComment-11922855
Yes and I have tried that, but some meens that it is a Bottleneck on the CPU.
https://linustechtips.com/topic/990141-low-fps-on-low-settings/#findComment-11922878
