Port Forwarding doesn't work
Go to solution Solved by homeap5,
You probably have mobile internet without external IP. Your connection uses T-Mobile proxy servers.
Ask T-Mobile for external IPv4. It's probably possible with extra monthly payment.
I powodzenia! :)
I am trying to port forward so people can join my minecraft server. The problem I am facing is that something seems to be blocking the connection. Everything seems to be set up right. I have tried disabling my firewall and also as many security settings in my router as possible. My friends can't connect and on https://www.yougetsignal.com/tools/open-ports/ it says that my port is closed. Please send help, I am so confused at this point. I am on a 4g connection with no static ip address (using no-ip).
https://linustechtips.com/topic/990104-port-forwarding-doesnt-work/
Might as well just rent a server then, thanks.
