Hi, i recently joined an esports organisation, and we are required to upload our csgo game play every week, therefore having at least 10 - 20 minutes worth of video after its been edited. now my problem is that i have been using OBS to record my gameplay, im recording at 1920 x 1080 @ 60FPS, but my monitor is 2560 x 1080 144Htz. When i play without recording i get 280+ fps, but when i start recording it drops as low as 75 FPS. i know it is not unplayable but it is very shakey and makes it very difficult to play and focus on being competitive if i have frame drops in clutch situations. I have a 8Gb  gigabyte auoris Rx 580 and an i7 6700k running at stock atm. my CSGO is also installed on my HDD and not one of my SSD's (dont know if having the gaem and obs on a SSD would help). is my  setup not good enough and if so would upgrading to a GTX 1070 or 1080 help?
https://linustechtips.com/topic/989611-bad-fps-when-using-obs/
What settings are you using in obs? Sounds like you should change your bitrate, the CPU is probably getting hit really hard.
Edit: can you capture 720 60fps instead? It would be less demanding in case you can't fix the framerate problem.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/989611-bad-fps-when-using-obs/#findComment-11917802
You have to change your bitrate and the settings you stream at. Honestly if you joined a Esports org and they required you to do this and didnt help, they arent worth your time.
https://linustechtips.com/topic/989611-bad-fps-when-using-obs/#findComment-11917806
Try GPU encoding, not x264. You'll get lower quality though (can be fixed partially with some tweaks)
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/989611-bad-fps-when-using-obs/#findComment-11917812
cpu is probably having trouble doing obs and csgo. I personally used the geforce shadowplay at 1080p60 and I don't get any frame drops with my gtx 960. Try the AMD gpu recording software and higher the bitrate while doing 1080p60.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/989611-bad-fps-when-using-obs/#findComment-11917828
what would you recommend me setting the bit rate to?
https://linustechtips.com/topic/989611-bad-fps-when-using-obs/#findComment-11918075
Should be a fast preset in your options.  https://www.gamersnexus.net/guides/2993-amd-1700-vs-intel-7700k-for-game-streaming should help
https://linustechtips.com/topic/989611-bad-fps-when-using-obs/#findComment-11918095
