1. Budget & Location
Roughly from $700-$900 USD, could go over but still want it to be reasonable.
2. Aim
The goal of this pc is to use it for streaming. I want it to be a streaming pc strictly. I'm not going to be playing while streaming - I have my console for playing the games. So, I'll be playing the actual game from my console, using the elgato to stream to my pc with OBS open as well.
3. Monitors
Just the 1 monitor. I also have a 2017 Macbook Pro that I could probably just use as a monitor, but nothing else.
4. Peripherals
I would need everything. Maybe not a mouse or a keyboard.
5. Why are you upgrading?
I'm upgrading because my elgato is having a tough time with my Macbook Pro. Even though it says on their website they're compatible with Macs, they don't actually detect the elgato as a capture device. Plus I could tell that if I stuck with my Macbook, it would get super hot and most likely lag.
Also, here are the spec requirements for the Elgato HD60s:
OS: Windows 10 (64-bit)
GPU: Intel HD, NVIDIA GeForce GTX 600 or better
CPU: Intel i5-4xxx quad core or better
Any advice is helpful! I am completely new to this pc world because I've only ever played on console.
Thanks!
https://linustechtips.com/topic/989470-first-build/
I can help you i will make a partpicker list for you.
Sorry for my bad English (I try to do my best)
My System
  • CPU
    AMD Ryzen 9 5900X
  • Motherboard
    ROG Strix B350-F Gaming
  • RAM
    32GB Trident Z
  • GPU
    Asus 2080 Strix O8G
  • Case
    Cougar Panzer
  • Storage
    970 Evo 250 GB + +1TB SSD + 1TB SSHD
  • PSU
    BeQuiet Straight Power 11 750w
  • Display(s)
    3
  • Mouse
    Roccat Tyon
  • Operating System
    Windows 10
https://linustechtips.com/topic/989470-first-build/#findComment-11916315
My System
  • CPU
    AMD Ryzen 9 5900X
  • Motherboard
  • RAM
    32GB Trident Z
  • GPU
    Asus 2080 Strix O8G
  • Case
    Cougar Panzer
  • Storage
  • PSU
  • Display(s)
    3
  • Mouse
    Roccat Tyon
  • Operating System
    Windows 10
https://linustechtips.com/topic/989470-first-build/#findComment-11916346
1 minute ago, Nirofix said:
I'd rather he go with a b450 tomahawk rather than a biostar board, and this cooler master case is only $30, excluding shipping.  https://www.newegg.com/Product/Product.aspx?Item=N82E16811119344&cm_re=cooler_master_case-_-11-119-344-_-Product
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/989470-first-build/#findComment-11916365
Yes or an strix b350 f gaming then u can use an 970 evo 250gb too
My System
  • CPU
    AMD Ryzen 9 5900X
  • Motherboard
  • RAM
    32GB Trident Z
  • GPU
    Asus 2080 Strix O8G
  • Case
    Cougar Panzer
  • Storage
  • PSU
  • Display(s)
    3
  • Mouse
    Roccat Tyon
  • Operating System
    Windows 10
https://linustechtips.com/topic/989470-first-build/#findComment-11916379
7 minutes ago, Nirofix said:
That Biostar motherboard is really bad though.
1060 is enough to meet the requirements, as it is about 25-30%, faster than a gtx 680.
https://linustechtips.com/topic/989470-first-build/#findComment-11916384
It would be easier if it was a b450 or x470 series, so that he would not have to update the bios
https://linustechtips.com/topic/989470-first-build/#findComment-11916388
Where do we get the 680 in this conversation
My System
  • CPU
    AMD Ryzen 9 5900X
  • Motherboard
  • RAM
    32GB Trident Z
  • GPU
    Asus 2080 Strix O8G
  • Case
    Cougar Panzer
  • Storage
  • PSU
  • Display(s)
    3
  • Mouse
    Roccat Tyon
  • Operating System
    Windows 10
https://linustechtips.com/topic/989470-first-build/#findComment-11916392
7 minutes ago, jschlenz said:
I love all of the responses, I appreciate them! Now, hear me out...how easy is it to build this stuff? Would a pre-built one do the job or would you suggest me just building it?
Building a PC is as easy as building Lego or building a shelf from ikea, just watch a few Tutorials on  YT
BUT NOT THE ONE FROM THE VERGE and you will easiely manage to build your pc
My System
  • CPU
    AMD Ryzen 9 5900X
  • Motherboard
  • RAM
    32GB Trident Z
  • GPU
    Asus 2080 Strix O8G
  • Case
    Cougar Panzer
  • Storage
  • PSU
  • Display(s)
    3
  • Mouse
    Roccat Tyon
  • Operating System
    Windows 10
https://linustechtips.com/topic/989470-first-build/#findComment-11916408
If you want you can contact me on Discord (Nirofix#3292) and i will guide and help you.
My System
  • CPU
    AMD Ryzen 9 5900X
  • Motherboard
  • RAM
    32GB Trident Z
  • GPU
    Asus 2080 Strix O8G
  • Case
    Cougar Panzer
  • Storage
  • PSU
  • Display(s)
    3
  • Mouse
    Roccat Tyon
  • Operating System
    Windows 10
https://linustechtips.com/topic/989470-first-build/#findComment-11916421
Haha ok for sure. I will look through all of the responses and the part pickers and check them out. I appreciate the help Nirofix!
https://linustechtips.com/topic/989470-first-build/#findComment-11916433
OP said the requirements were gtx 600 series or later, don’t know if it means high end or low end 600 series, so i assumed it was high end and based gpu choice off the performance of 680
https://linustechtips.com/topic/989470-first-build/#findComment-11916459
A prebuilt will do the job, but building it yourself is pretty fun and is cheaper(no need to pay extra for someone to build it for you). It’s a good skill to learn.
It’s not hard at all, i taught my friend who didn’t know anything about PCs how to build one, by building it with him. Towards the end he managed to install the water cooler on the CPU by himself, as well as plug in the case fans(and route them neatly as well). Just refer to helpful videos on youtube like this: https://youtu.be/IhX0fOUYd8Q
Have fun! :)
https://linustechtips.com/topic/989470-first-build/#findComment-11916480
46 minutes ago, jschlenz said:
Build something like this instead...
CPU: AMD - Ryzen 7 1700 3GHz 8-Core Processor  ($179.89 @ OutletPC)
Motherboard: ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard  ($79.99 @ Newegg)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($119.99 @ Newegg)
Storage: Samsung - 860 Evo 500GB 2.5" Solid State Drive  ($86.99 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($58.89 @ OutletPC)
Video Card: PowerColor - Radeon RX 580 8GB Video Card  ($204.98 @ Newegg)
Case: NZXT - H500 (Black) ATX Mid Tower Case  ($69.99 @ Amazon)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.99 @ Amazon)
Total: $850.71
Generated by PCPartPicker 2018-10-31 17:29 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/989470-first-build/#findComment-11916512
Easy AF.
Just don't buy any of the cheap suggested SSDs, buy a Samsung EVO.
Rest In Peace my old signature...                  September 11th 2018 ~ December 26th 2018
https://linustechtips.com/topic/989470-first-build/#findComment-11917131
