Hey, I have a question if a Dark Rock Pro 4 would fit in a Photios 250, I´m kinda confused about the "depth (????)"  of the cooler and would need advice. I´d like to get my i5 8600k to 5GHZ, and if the Dark Rock Pro 4 doesn´t fit - Any other recommendations?
https://linustechtips.com/topic/989021-need-help/
Cooler is 162,8mm tall, case fits up to 155mm, so that wont work.
The Cryorig H7 would be an alternative, but it is a bit louder (or cools less if you have it at the same noise level).
https://linustechtips.com/topic/989021-need-help/#findComment-11911749
The H7 is both louder and worse at cooling.
Where are you shopping / located? Budget?
https://linustechtips.com/topic/989021-need-help/#findComment-11911768
at those freq it is highly recommended you go with a CLC or AIO it also has advantage of being able to place rad were it will fit.
PSU Tier Ranking List
Ryzen 5 1600x|ASROCK                      |16GB DDR4 3400Mhz Corsair Vengence   | (partial build in progress)
FX-8350 AM3+| ASUS M5A990FX V1 | 32GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H100i v1
FX-8120 AM3+| ASUS M5A990FX V2 | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H80i v1
I5-2500K LGA  | ACER MOBO??         | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 860 PRO | Win 10 64 Pro | EVGA 750W G PSU | EVGA 970 SC 4GB | Corsair H80i v1
https://linustechtips.com/topic/989021-need-help/#findComment-11911790
1 hour ago, Mentos said:
 I´ll be considering the H7, are there any other considerably good coolers under 155mm height?
If you are height limited then a top flow cooler is a great choice. Either a Noctua NH-C14S or DarkRock TF would work great in this instance.
https://linustechtips.com/topic/989021-need-help/#findComment-11912292
I did some research on my case but I didn´t find really anything to it. It only says "maximum CPU Cooler height 155mm", I have no idea about cases and I got this case recommended a couple times. I´m not sure if the Dark Rock TF will fit? It also doesn´t say anything about max Length and width
Case: Photios 250
https://linustechtips.com/topic/989021-need-help/#findComment-11914636
Case: Photios 250
Yes the DRTF fits. The cooler doesn't extend past the motherboard so the height is the usually the only spec that matters.
Despite the cooler fitting, it's suboptimal in a case like the Photios 250 since the fan is facing a solid panel instead of an open mesh. A traditional tower style heatsink would be better since it could face the same direction as the case fans.
https://linustechtips.com/topic/989021-need-help/#findComment-11915914
The DRTF (And C14S) are only about 130mm tall. He has 155mm of space. That's 25 mm of space above the cooler which is more than plenty. So long as he has his case fans setup good it's not a problem. The sheer beefiness of these coolers far outweighs the airflow provided by a smaller tower cooler. Also a top flow cooler has the benefit of cooling VRMs on the motherboard better.
Both the DR TF and NH-C14s are about the same lateral dimensions as an ITX motherboard. So if you have an ATX case it will definitely fit if it's short enough. Which these are.
https://linustechtips.com/topic/989021-need-help/#findComment-11916753
That's why you you compare the cooler to one of a similar size instead.
https://linustechtips.com/topic/989021-need-help/#findComment-11916761
4 minutes ago, geo3 said:
A similar sized tower cooler won't fit in his case.
The Mugen 5 Rev. B is an example that fits in the case and would probably perform better.
https://linustechtips.com/topic/989021-need-help/#findComment-11916789
