Two independant GPU's, one system.
If I were trying to build a PC that could have a strong gaming performance and the ability to run GPU intensive programs i.e. Solidworks, should I use a GTX 1080 for gaming and a Quadro p2000 for CAD (they are my preferred cards based on my budget) or is their another card or method I should try that would get similar results in both Gaming and CAD.
If I were to use a a gtx1080 and p2000 how would I go about having them in the same system but running independently ( not necessarily simultaneously tho.)
I'm trying to avoid building two systems with two CPUs, Motherboards, etc. and keep total cost low, I'm in High school so money is not plentiful at the moment.
Thanks for any help I can get.
https://linustechtips.com/topic/988202-two-independant-gpus-one-system/
Hey there.
GPU's like the p2000 are not aimed at gaming, they're aimed CAD as you said. But that doesn't mean you can't game on them. Buying a p2000 will serve you well in CAD and in gaming. You can check some benchmarks. There is no need in buying 2 different GPU's I think.
Have a nice day.
  • CPU
    Intel Core i7-6700K Skylake 4.0GHz 8MB - Sk 1151
  • Motherboard
    MSI Z170A GAMING PRO CARBON - SK 1151
  • RAM
    HyperX Fury 16GB (4x4GB) DDR4-2400MHz CL15
  • GPU
    Asus ROG Strix GeForce GTX 1060 6GB OC
  • Case
    DeepCool Tesseract SW
  • Storage
    SSD 2.5" Kingston SSDNow UV400 120GB TLC SATA + HDD 3.5" Seagate Barracuda 1TB 7200RPM 64MB SATA III + HDD 3.5" Seagate Barracuda 1TB 7200RPM 64MB SATA III
  • PSU
    XFX TS 550W
  • Display(s)
    HannsG HW191D 19" Widescreen LCD TFT
  • Cooling
    Cooler Master Seidon 120V VER.2
  • Keyboard
    Cooler Master Storm Octane Combo
  • Mouse
    Steelseries Rival 100
  • Sound
    Logitech Z333
  • Operating System
    Microsoft Windows 10 Pro 64-bit
  • PCPartPicker URL
