Water Cooling "PETG" fittings for soft tubing?
Solved by reptileexperts,
No. you need Advanced compression fittings or barb fittings only for soft tubing. Rigid tubing has a lot different design including o-rings.
Featured Topics
Gas Racing ·
1
2
1
2
Matt_in_NE ·
Posted in Troubleshooting1 -
play_circle_filled
Latest From ShortCircuit:
I'm a Huge Sucker for a Cool Gimmick - Epomaker DynaTab 75X & DynaTab 75
play_circle_filled
Latest From Mac Address:
The Apple Vision Pro Leaves a Mark (but not the right kind)
