1 minute ago, Crazymacc said:
Yea i have tried this but it doesn't free much space up. Could I hypothetically move my files to my d drive?
yes, depending on which files, dont move the os (obviously), im assuming that your c drive is an ssd, and your d drive is a hdd. if you have steam games install a program to move the game here: http://www.traynier.com/software/steammover . you will have to change the default library in steam. What files take up most of your storage? Programs, documents games?
Why wouldn't you be able to move your files? It should be just that simple.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://gyazo.com/580b2af2e6eef41d80776735a9b3dfda
https://gyazo.com/ad3be47bd563fd9d2c91132ad39a4488
Thats literally it. I am just confused about how that could use so much  space.
which specific folders are taking up the most space, theres a program called treesize which is very useful for showing size of folders and can analyze what takes up most storage
https://gyazo.com/ecbab9a1117b884cff1ebdfffed1aee3   ????
12 minutes ago, Si1veRYT said:
Download a program called ccleaner, free up some space, maybe not enough though.
CCleaner should be used a final resort.
I see that you have a 'Rockstar Games folder', which to me says that you have games installed on that drive which may be hogging space. Also you have an 'Epic Games' folder hinting you have Fortnite installed as well. And Stearm, and Ubisoft...
Quote
"I really couldn't find anything to remove"
You also have a few editing program files for Boris FX & Adobe. Microsoft Office Suite & Avast Anti Virus also will take up a lot of space
I once did the unthinkable, back many headphones ago...
I split an audio split, again
I have a hdd and an ssd, i have the rockstar folder on my ssd but the game on the hdd. I dont think the game is installed there :)
I don't have the games installed, they are just the game launchers, not the games themselves.
It looks like you may have solved your problem. But in case this happens again, but not with CSGO stuff, you can change the location of your dekstop folder, documents folder, etc by right-clicking and going to properties>location. This can free up TONS of space, depending on use case.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
Thanks very much, will do that too.
