Hello I just got this supermicro g34 socket board. It has 4 opteron 6276 cpus 64 cores with 36 gb ddr3 and a 1000w psu.
It turns on it boots I can get to the bios screen I can also use a usb to instal windows, but I can't get the sata ports to show up at all. I tried booting of a hdd ssd and a usb not one let's me boot off it. Also they don't show up under my storage devices. I tried to install drivers for it and re flashing the bios it's the most up to date bios 3.5 2016. The model is a H8qgi-f if there any drivers any would help.  Thanks any info would really help me out
https://linustechtips.com/topic/987368-sata-ports-not-working/
SATA controller might be toast. Maybe try a PCI(e) SATA card.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/987368-sata-ports-not-working/#findComment-11895903
