Hello! This is my first ever desktop build and I wanted some opinions on it. Just saying this build was not all me. My friend, who just so happens to be pretty good at building PC's, helped me pick some parts out. Right now I'm using a laptop hooked up to a TV and that doesn't really satisfy my need to play demanding games. The only game I can play on good graphics right now using my laptop is League of Legends and that's not really something to brag about. I would like to play games like Farcry 5, Rust, Skyrim (with a good amount of mods), and obviously League of Legends. I appreciate all feedback and tips. Thank you!
PCPartPicker part list: https://pcpartpicker.com/list/p2pq7W
Price breakdown by merchant: https://pcpartpicker.com/list/p2pq7W/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($159.89 @ OutletPC)
CPU Cooler: be quiet! - Dark Rock 4 CPU Cooler  ($66.99 @ SuperBiiz)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  ($88.88 @ OutletPC)
Memory: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3000 Memory  ($139.99 @ Newegg Business)
Storage: ADATA - Ultimate SU800 128GB 2.5" Solid State Drive  ($28.99 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($58.89 @ OutletPC)
Video Card: EVGA - GeForce GTX 1070 8GB SC Gaming ACX 3.0 Video Card  ($359.99 @ Amazon)
Case: Inwin - 101 Black ATX Mid Tower Case  ($69.99 @ Amazon)
Power Supply: EVGA - BQ 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($39.99 @ Amazon)
Total: $1013.60
(Thank you bleedblue)
Edited by zzSheep
https://linustechtips.com/topic/986124-first-build-ever/
Did you tell him that you 'will overclock a little bit' and a Nvidia fanatic?
Desktop benching:
https://linustechtips.com/topic/986124-first-build-ever/#findComment-11883301
Total: $1013.60
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/986124-first-build-ever/#findComment-11883310
27 minutes ago, zzSheep said:
I'm not entirely sure what overclocking is.
Its basically when you make your cpu, gpu, and/or ram go faster. I wouldn't recommend doing crazy overclocking as it can reduce the life of your parts and if you do plan on it then make sure you have good cooling.
CPU: Intel I5-7500
CPU Cooler: Cooler Master ML240
Motherboard: ASRock B250M PRO 4
Memory: 16GB Patriot Viper Elite
Gpu: Asus Dual 1060 3GB
Storage: Corsair 120GB M.2 NVME
500GB Samsung 860 EVO
1TB WD Blue
Power Supply: EVGA 500W 80+Bronze
Case: Phanteks P350X
Monitors: HP Omen 25in 144hz
and some 25in Acer
Keyboard: Corsair K70 LUX RGB
Mouse: Corsair M65 Pro
Headphones= VModa Crossfade Wireless(but used wired)
Speakers: Some janky speakers I jerry-rigged
https://linustechtips.com/topic/986124-first-build-ever/#findComment-11883344
My take on a $1000 budget
Shaved off some cooler capabilities because you dont need that good of a cooler if you don't overclock aggressively
Swapped mobo and RAM for essentially the same performance
Increased SSD space, because fast storage is always welcomed and SSDs are getting cheap compared to how they were
Swapped to Vega 56, not only the same price for more performance than the 1070, also supports Freesync. Freesync monitors are cheaper than Gsync ones so the feature is more affordanle to use.
Changed case, I have no idea how the Inwin 101 breath, but I do know it's a bit expensive for what it is
Changed PSU, because you could get better for spare change in your pocket.
Desktop benching:
https://linustechtips.com/topic/986124-first-build-ever/#findComment-11883358
Oh ok. Thank you for clearing this up.
https://linustechtips.com/topic/986124-first-build-ever/#findComment-11883370
I didn't know I chose such an overkill cooler. Thank you! This helps a lot.
https://linustechtips.com/topic/986124-first-build-ever/#findComment-11883373
As long as you get something better than that garbage PSU you listed first, you'll be ok lol
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/986124-first-build-ever/#findComment-11883383
that's actually @bleedblue list. The first list's an 8600k on crap Z370 mobo and underneath crap cooler.
Desktop benching:
https://linustechtips.com/topic/986124-first-build-ever/#findComment-11883385
Don't know much about ASRock or air coolers so /shrug
The OP never gave a budget and resolution/refresh rate he wants to play at either.
https://linustechtips.com/topic/986124-first-build-ever/#findComment-11883390
the first build does end up at about $1000
Desktop benching:
https://linustechtips.com/topic/986124-first-build-ever/#findComment-11883393
