I have a few spare HDD that I want to RAID together to make a single large 'high speed' game drive. I saw windows 10 has 'storage spaces' but from my light research it looks like it's not as efficient as an actual RAID 0 array. What tools would I need to start a software based array? Also in this scenario, would a hardware RAID make more sense?
I have windows 10 installed on a 240 ssd with some other programs, and I currently have a HDD installed for my games right now. Would I still need to reinstall windows 10 before I start (I can I would just rather not)?
https://linustechtips.com/topic/985978-help-with-starting-raid-0/
25 minutes ago, Slaps_Only said:
Why would you want to risk your data on a daily basis?
You could add another SSD to do caching for the hard drives, or split your current SSD to use half of it for caching.
I don't have any critical data one my computer. Everything important is saved externally. Anything I can't recover from a cloud storage or service is saved onto a flash drive. My HDD would only hold a steam library which i can easily re-download if a disk or the raid fails. I had never considered caching though.
4 hours ago, karsnoordhuis said:
i dont see why you want to reinstall windows. you can set raid 0 up in your bios if your mobo supports it, this is the most effective way i believe
I don't want to reinstall windows. I sort of assumed a fresh install would make things easier.
Windows has built in caching software or linus lists a few here
I really wouldn't bother with RAID 0 at all though unless you just want to run one benchmark for fun.
Just now, Electronics Wizardy said:
Since its not a boot drive just make a raid 0 with storage spaces in windows. Simple and much better than using the bios for raid.
Are 'storage spaces' and RAID 0 the same? I was under the impression they were similar but RAID 0 was still faster.
Storage spaces is the raid management system in windows
You can make a raid0 in storage spaces and it will preform just like any other raid0. Just be sure to set the collums correctly.
Excellent. Thank you for the info!
I think he indicated it was a game or scratch drive, so I wouldn't worry about it.
OP you can just assign those drives to an array after changing to raid mode, I have a couple of ssd in the same configuration.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
Still a waste of time setting up RAID0 for gaming.
I used to run RAID0 for my game drive, I now just run a WD Black and its pretty much the same.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
