Hello, recently I have been looking at my temperatures on my PC parts using CAM and Afterburner and noticed that my CPU has been running insanely hot - 90-100c while under low loads. The CPU is an Intel Core i7-8700K so its a new model as well. I'm not very good at PC parts so I don't know if this is thermal paste issues and if it is that I don't know how to go about fixing that or anything - CAM_V3_2018-10-20_14-28-24.png
Thank you!
Edit: The CPU to my knowledge isn't overclocked, I'm currently using a CyberpowerPC Asetek 550LC (White Color) 120mm Liquid Cooling CPU Cooler (Single Standard 120MM Fan)
https://linustechtips.com/topic/985259-overheating/
First thing to do is to Check your BIOS for your fan settings. Then, check the fan leads to be sure they're plugged in, and make sure the fan is spinning.  Lastly, pull your heatsink / cooler and check paste application.
You definitely have a cooling issue.
Main Rig:
Case: Lian Li Lancool Mesh RGB
CPU: Ryzen 5 3600
Cooler: CoolerMaster MasterLiquid 240
MB: MSI B550 Gaming Pro Carbon
Ram: Gskill DDR4 3600 x 32GB
GPU: Asus Arez Strix Vega 64 OC
PS: Seasonic FOCUS Gold Plus Series SSR-750FX
SSD1: Crucial P1 1TB NVME
SSD2: Adata SU800 512gb M.2 Sata
HDD: Hitatchi 2tb 7200RPM + 3x 2TB WD Passport USB 3.0
Monitors: AOC C24G1
Keyboard: Cheap Blue Knockoff Mechanical
Mouse: Uhuru Gaming Mouse
OS: Pop! 21.04
Current Vintage Equipment:  Please ask me about it, I love to talk old tech!
IBM Thinkpad 390, IBM Aptiva A12, IBM PS/2 Model 25-004.  Compaq Contura 4/25C, Presario 7596
Asus P5A-B Socket 7 Box, Tandy 1000RLX-HD "B" & 1200-2FD, VIC20, Zenith ZFL-181-93, Packard Bell 300SX.
Apple II/gs, Mac Plus x2, Mac SE x2, Performa 450
https://linustechtips.com/topic/985259-overheating/#findComment-11875517
If you’re overclocked at all, take that off right away lol. The max you want to see for every day use is probably no more than about 80C. You might need to use a little (a LITTLE) more thermal paste, or possibly less even (most likely less), or maybe your cooler isn’t tightened down enough
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/985259-overheating/#findComment-11875563
22 minutes ago, MonkeyManofLife said:
Hello, recently I have been looking at my temperatures on my PC parts using CAM and Afterburner and noticed that my CPU has been running insanely hot - 90-100c while under low loads. The CPU is an Intel Core i7-8700K so its a new model as well. I'm not very good at PC parts so I don't know if this is thermal paste issues and if it is that I don't know how to go about fixing that or anything - Thank you!
First off, what CPU cooler are you using?
https://linustechtips.com/topic/985259-overheating/#findComment-11875588
First things first...
Get rid of NZXT CAM, there are better tools out there for measuring temps.
Was there any kind of plastic film on the baseplate of the cooler?
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
https://linustechtips.com/topic/985259-overheating/#findComment-11875625
Too my knowledge the CPU isn't overclocked however it may be It shouldn't be though. I am currently using a CyberpowerPC Asetek 550LC (White Color) 120mm Liquid Cooling CPU Cooler (Single Standard 120MM Fan) as my CPU cooler.
Thank you!
Also, what tools do you recommend using?
https://linustechtips.com/topic/985259-overheating/#findComment-11875777
What motherboard are you using? Touch the tubing and try to feel for the flowing fluid if any and double check to see if the pump header isn't unplugged.
https://linustechtips.com/topic/985259-overheating/#findComment-11875789
A single 120mm radiator is a bit small for the 8700K. A similarly priced air cooler probably would have done you better. As for programs, I use MSI afterburner, as do many other people. It monitors both CPU and GPU. Your motherboard will likely include software for fan control also that you can use in the OS, or you can control it directly from the BIOS. Make sure both the pump and the fan speed up when the temps increase. You can also check to make sure the pump is working by touching the pump and/or the tubes while it’s running, it should vibrate.
https://linustechtips.com/topic/985259-overheating/#findComment-11876436
It was vibrating, however, I have been hearing a weird sound coming from it like it's not full or something. Kind of a loud sound aswell.
https://linustechtips.com/topic/985259-overheating/#findComment-11882568
Send it back. An AIO should have little enough air in it to not have a priming issue. I would send it back and get a decent air cooler or a better AIO, at least a 240mm so you can keep the fans from running at 100% trying to keep up..
Setup: 8700k - Asus Maximus Formula X - EVGA XCII 2080ti - 2x16GB ddr4 3000 - EVGA G3 1000w - Carbon Cablemod Cables- Custom EKWB cooling loop - phanteks enthoo luxe 2
https://linustechtips.com/topic/985259-overheating/#findComment-11888343
