You have nothing to tell the GPU what to do and nothing to supply the PCIe power either. This is completely normal and I would almost say you risk causing more issues by hooking it up to the PSU directly without a motherboard than just waiting.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/985145-help/#findComment-11874509
The PSU won't even turn on unless you short the pins on the 24 pin that tell it to. So nothing abnormal is happening
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/985145-help/#findComment-11874513
i did for few seconds thats dumb did i broke my gpu or will it be fine
https://linustechtips.com/topic/985145-help/#findComment-11874514
Did you jump the PSU or just connect them and flip the switch? If you didn't jump it then nothing happened, otherwise you run a VERY small risk but I would say since the GPU isn't initialized it won't draw power so no risk there.
Prior Build Log/PC:
https://linustechtips.com/topic/985145-help/#findComment-11874516
Like was mentioned above, unless you jumped the pins on the 24-pin then nothing will happen.
Prior Build Log/PC:
https://linustechtips.com/topic/985145-help/#findComment-11874518
no i dont have a mobo rn just psu and gpu
https://linustechtips.com/topic/985145-help/#findComment-11874523
