Bluetooth headphones don't work on PC
DOGEY
So, before 15 minutes i get a bluetooth adapter. Because i want to use my wireless headphones. (broke 6 times headphones bc of cables) And it says that it is connected the lights on the headphones is red, and for the worst there isn't sound. HOW?!
Have you tried to see if its the default audio device first? That would be the easiest thing to do xD
Primary Laptop (Gearsy MK4): Ryzen 9 5900HX, Radeon RX 6800M, Radeon Vega 8 Mobile, 24 GB DDR4 2400 Mhz, 512 GB SSD+1TB SSD, 15.6 in 300 Hz IPS display
2021 Asus ROG Strix G15 Advantage Edition
Secondary Laptop (Uni MK2): Ryzen 7 5800HS, Nvidia GTX 1650, Radeon Vega 8 Mobile, 16 GB DDR4 3200 Mhz, 512 GB SSD
2021 Asus ROG Zephyrus G14
Meme Machine (Uni MK1): Shintel Core i5 7200U, Nvidia GT 940MX, 24 GB DDR4 2133 Mhz, 256 GB SSD+500GB HDD, 15.6 in TN Display
2016 Acer Aspire E5 575
Retired Laptop (Gearsy MK2): Ryzen 5 2500U, Radeon Vega 8 Mobile, 12 GB 2400 Mhz DDR4, 256 GB NVME SSD, 15.6" 1080p IPS Touchscreen
2017 HP Envy X360 15z (Ryzen)
PC (Gearsy): A6 3650, HD 6530D , 8 GB 1600 Mhz Kingston DDR3, Some Random Mobo Lol, EVGA 450W BT PSU, Stock Cooler, 128 GB Kingston SSD, 1 TB WD Blue 7200 RPM
HP P7 1234 (Yes It's Actually Called That)  RIP
Also im happy to answer any Ryzen Mobile questions if anyone is interested!
No it's not. But everything i try, sound control panel, drivers, etc. Nothing seems to work.
2 minutes ago, DOGEY said:
No it's not.
Then set it as a default audio device?
I only see your reply if you @ me.
This reply/comment was generated by AI.
I can't. But i see that something called stereo mix is disabled should i enable it?
I will try cinebench to test my CPU, if it damaged it. (I don't think so) Also i will never ever use bluetooth on my PC. Nothing is damaged yay... It is not destroyed yet because i want to try again! If i get blue screen again idfc about the adapter i will broke it with a hammer it costs only 2.50$ so... Heyyy i understand it was usb 2.0 so!
