I was wondering how feasible it would be to take an air cooled pc, put beast hardware in it, seal it up, and drop it in a bucket it of water. Eventually, my idea is to use the pc case as a giant water cooled heatsink. Would you need to pump the water still? Using this method could you also get a fanless setup? Is this just generally a bad idea anyway? Either way, I think it would make a good LTT video.
https://linustechtips.com/topic/984531-external-water-cooling/
Sounds like a terrible idea. I'm no physicist, but won't doing that make your PC case into a hot/cold drink flask?
If I'm not mistaken sealed steel container +air= insulator.
And I'm pretty sure steel doesn't conduct heat that well.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/984531-external-water-cooling/#findComment-11869488
well, the reason I specifically mentioned modding an air-cooled case was because some of them have metal bars going from the heatsink to the case, so the heat can dissipate throught the metal bar to case rather than the air. I apologize for not making that clear.
https://linustechtips.com/topic/984531-external-water-cooling/#findComment-11869496
Not sure if trolling.
You're basically talking about a mineral oil PC.  Yes you still need a radiator and fans to cool the oil.
If you're talking about something else like using the case as a heatsink and dunking the case in water...that's just idiotic, there's way better ways to deal with cooling than that.
If you'reo talking about one of those passively cooled vaporchamber type systems and dunking that in oil...yeah it would probably work but again there's better ways to deal with cooling.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/984531-external-water-cooling/#findComment-11869497
Actually I'm pretty sure there's already a case that uses its side-panels as heat-sinks, I remember watching a HW Canucks video on it. I guess if you really needed to you could seal that case up with sealant and throw it into a body of water...
It's still a terrible idea though.
https://linustechtips.com/topic/984531-external-water-cooling/#findComment-11869507
Would I ever build this pc? No. However, I think might have some small benefits over traditional water cooling and a mineral oil pc. Unlike the mineral oil pc, you don't get any of your components oily. Also, unlike traditional water cooling, you get a huge heatsink for more heat transfer to the water.
https://linustechtips.com/topic/984531-external-water-cooling/#findComment-11869513
The thing about water cooling heat sinks is that they're not surrounded by water. Take the fins on a PC radiator for example. Are those submerged? Certainly not, because they need airflow over them. You say the heat sink on the outside would transfer heat from the PC into the water, but from there it goes nowhere. Since air is the ambient medium on dry land, not water, you'd need to basically be operating this PC in the ocean for the submerging effect to be of any use, since the heat needs to dissipate outward "infinitely" to actually cool the system without just creating a box of heat around the heat generating components. Same reason a mini fridge doesn't work as a cooler, the air is all trapped inside and just hot boxes the PC,
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/984531-external-water-cooling/#findComment-11869529
