Hi all, I have a Behringer Ultravoice Xm8500 mic and a Behringer U-Phoria UM2 preamp/dac. My mic has a constant buzzing noise in the background, and it isn't very loud, but it's noticeable enough to annoy me when I record audio. I have the mic on a steel arm. I can't figure out what the problem might be aside from noise through the USB port my preamp/dac is plugged into. If it is noise from the port, how do I fix it? If it isn't, what could the problem be, and how do I go about isolating the issue and solving it? I'm pretty new to this setup. Thanks!
Everything I know I learned from the internet. Also school.
Current Desktop:
CPU: Ryzen 5 1600 @3.65 ghz, Cryorig H7
MoBo: Asus Prime X470-Pro
GPU: Gigabyte RTX 2060 Super OC
RAM: 2x8 gb Corsair Vengeance LPX DDR4 @2666mhz
PSU: 650W EVGA SuperNova
Storage: 120gb SK Hynix SSD, 240gb SanDisk SSD Plus, 1 TB 2015 WD Blue
Case: Corsair Carbide 100R
Peripherals: Logitech G Pro keyboard, Razer DeathAdder Elite, Logitech G305, Logitech G600, 24" AOC FreeSync 1080p monitor x2
https://linustechtips.com/topic/984493-buzzing-noise-on-mic/
How high have you turned up your gain on the mic? Generally, loud background noise is a sign of high gain.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/984493-buzzing-noise-on-mic/#findComment-11869175
The physical knob on my preamp is at about 50%. I'll try messing about with that and see if it fixes the problem.
Current Desktop:
https://linustechtips.com/topic/984493-buzzing-noise-on-mic/#findComment-11869238
I wrote this article that may help you ID the source and find a solution to the problem. These issues can happen to any mic really.
Hope it helps! https://antlionaudio.com/blogs/news/whats-that-noise
Director of Marketing for Antlion Audio, creators of the ModMic.
More info at www.ModMic.com
Ask questions, I'm friendly!
https://linustechtips.com/topic/984493-buzzing-noise-on-mic/#findComment-11869329
