So i cant decide which of these 2 to choose
asus rog (gl702zc) RYZEN 7 1700 RX580 16gb ddr4 (runs hot)
or
Latest Acer Predator Helios 300 i7 8750h gtx 1060 6gb 4x4gb ddr4 ram (agrressive look )
Ill be using it for architectrual stuff, Vray, Lumion and other rendering software. And maybe suggestions for about $1500 below laptop
https://linustechtips.com/topic/984346-help-me-choose-laptop/
I'd get the first one, even if it does run hot.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/984346-help-me-choose-laptop/#findComment-11867674
Both laptops are very similar but I recommended the first one over the acer.
ryzen is 20% better as a workstation which will benefit you more.
Both gpu's are very similar - I have a desktop 580 8gb and can play most games on high / ultra on 1080p
also 16gb is nice for workstation and gaming
https://linustechtips.com/topic/984346-help-me-choose-laptop/#findComment-11867697
Both are mediocre
Where are you from? Preferred max weight and min battery life?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/984346-help-me-choose-laptop/#findComment-11867736
1 hour ago, GeneXiS_X said:
Both are mediocre
Im from the Philippines, i really dont care much about weight as long i can put it in my backpack and battery life for the asus is sure bad but i can manage plug and play
https://linustechtips.com/topic/984346-help-me-choose-laptop/#findComment-11867988
Any links of online stores?
Desktop specs:
https://linustechtips.com/topic/984346-help-me-choose-laptop/#findComment-11879880
