Case - Airflow Question
Solved by LogicalDrm,
For dual GPUs, its recommended to use blower style cards. You are gonna have cards very close to each other and the upper card will lack air for cooling.
Airflow-wise single card will be fine. Dual cards... probably not that much. Seeing how close PSU shroud comes to single card, the bottom card would have almost as lacking airflow as top one.
6 minutes ago, Hi P said:Would I be better off with a front mesh case?
Not. You are better off getting case without PSU shroud. Those who test cases say that shroud is bad for airflow. As you can add fans to bottom to provide more, with shroud you are taking off both bottom and bottom-front fans from GPU cooling case fans.
