I'm in the market for a new GPU, I'm technically upgrading from a GTX 970.
Looked around and saw the AORUS RTX cards but can't seem to find them anywhere...
I'm assuming they're not released yet, any word on release/Canadian release?
https://linustechtips.com/topic/984123-aorus-geforce-rtx-cards/
they are released, if you can look aside from Aorus.
How much can you spend?
Desktop benching:
https://linustechtips.com/topic/984123-aorus-geforce-rtx-cards/#findComment-11865548
Budget isn't too fixed, anywhere from 900 to 1600 Canadian Rupees.
I specifically want the Aorus Models as they have the longest warranty (And that is something that I'll eventually need to use, apparently >.>)
Thanks
https://linustechtips.com/topic/984123-aorus-geforce-rtx-cards/#findComment-11865559
dont they have 2-3 years only? I remember Zotac having 5, EVGA having 3
Desktop benching:
https://linustechtips.com/topic/984123-aorus-geforce-rtx-cards/#findComment-11865567
I was looking around, I don't remember Zotac, but i don't think it was 5 for the cards i was looking at. EVGA Does have 3. Aorus has 3 but you can get an extra year for signing up.
EDIT Zotac has a 5 year warranty, seemingly only in EU/USA? Not Canada :(
https://linustechtips.com/topic/984123-aorus-geforce-rtx-cards/#findComment-11865589
at least EVGA has better customer service than all of them... So it's fighting with Gigabyte customer service for 4 years or paying EVGA to fix the card after 3 years, your pick.
Desktop benching:
https://linustechtips.com/topic/984123-aorus-geforce-rtx-cards/#findComment-11865603
Mhmmm... That is a good point. I might just go EVGA then, and once my card eventually decides to crap out, get an RMA, flip the RMA card and get a new one.
Thanks!
https://linustechtips.com/topic/984123-aorus-geforce-rtx-cards/#findComment-11865859
