Hey Guyz..
i have 4 sticks of 2 gb ddr3 ram i ghave installed it in my desktop but my bios shows that 3 channels are active i m really confuse waht is single channel , dual channel or quad channel etc etc.. i have attached my motherboard picture.. it is a dell precision t3500 mother board kindly help.. if you can marked the slots in the picture then it will be much more easier for me
dell-precision-t3500-socket-1366-motherboard-9kpnv-k095g-xpdfk-beginner28-1604-08-beginner28@3.jpg
https://linustechtips.com/topic/983966-help-me-installing-ram/
The slots are already marked by color. Since this is a 1366 platform, you are supposed to install ram in sets of 3 for triple channel, which is done by populating either the white slots only or all of them. If you want to use 4 sticks, just populate from the CPU socket up and you'll run dual channel.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/983966-help-me-installing-ram/#findComment-11864014
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
https://linustechtips.com/topic/983966-help-me-installing-ram/#findComment-11864024
What you building here or is that a stock photo off the internet
Thermatake Tower 900 Build
Intel® Core™ i7-7700K @5.3GHz -2AVX / ROG MAXIMUS IX APEX + EK-FB ASUS M9A Monoblock
ROG-POSEIDON-GTX1080TI 11Gb @2114MHz/5780Mhz / DIMM.2 970 EVO 2TB NVMe PCIe M.2 x2 RAID 0
EVGA SuperNOVA 1600 P2 80+ PLATINUM / Hisense 65" H9 Plus 4k HDR
https://linustechtips.com/topic/983966-help-me-installing-ram/#findComment-11864044
what is better in your opinion dual channel or triple channel which is showing in the bios right now? i want to mention again that i have four stick of 2 gb
https://linustechtips.com/topic/983966-help-me-installing-ram/#findComment-11865704
