Help with 144 and 75 hz monitors
Guest
Right now I have a 75 and a 60 hz set of Monitors, but I want to upgrade to a 144 and a 75 but I’m worried it will screen tear really badly, I have FreeSync but I need help. Another problem is I’m not sure what to upgrade my
cpu and gpu to when getting a this, my current is a i5-6400 for my cpu and  arc 470 as gpu
well if you have an amd gpu, just get any freesync monitor and tearing shouldn't be an issue anymore.
for your upgrade it depends on what game you wanna play.
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
If you want to buy a 144hz monitor to play some heavy games than i suggest some beefy gpu to keep up with the refresh rates.
580's are cheap rn, and a 2600 with a good mobo is what i would suggest for an upgrade.
but for thearing is g-sync the best, but also the most expensive
