Is it impossible to find a 1080p Monitor for <$100?
Guest
I live in Canada, and looking at all the sites it seems like the cheapest 1080p monitor you can buy is at least $110. I don't want anything fancy, just a second display to watch videos on, but $100+ seems way too expensive for the cheapest, now outdated, monitor.
I use an ~$80 AOC panel
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
Welcome to the Canadian Dollar.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
Try this?
Thoughts become things. What you hold in your mind, you will hold in your hand.
Be happy for yourself.
My rig :) :
PCPartPicker Part List: https://pcpartpicker.com/list/tX4hWD
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor
Motherboard: Asus - Prime X470-Pro ATX AM4 Motherboard
Memory: Corsair - Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive
GPU: Gigabyte - GeForce GTX 1080 Ti 11 GB AORUS Video Card
Case: Fractal Design - Meshify C ATX Mid Tower Case
Power Supply: SeaSonic - FOCUS Plus Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply
Operating System: Microsoft - Windows 10 Home OEM 64-bit
Monitor: AOC - G2770PQU 27.0" 1920x1080 144 Hz Monitor
Keyboard: Corsair - K70 RGB RAPIDFIRE Wired Gaming Keyboard
Mouse: Corsair - Sabre RGB Wired Optical Mouse
Custom: Beyerdynamic DT 770 PRO, 250 ohms
