34 minutes ago, Txe said:
Anyone know any software to control fans directly from windows
Whats your motherboard manufacturer?
Thermatake Tower 900 Build
Intel® Core™ i7-7700K @5.3GHz -2AVX / ROG MAXIMUS IX APEX + EK-FB ASUS M9A Monoblock
ROG-POSEIDON-GTX1080TI 11Gb @2114MHz/5780Mhz / DIMM.2 970 EVO 2TB NVMe PCIe M.2 x2 RAID 0
EVGA SuperNOVA 1600 P2 80+ PLATINUM / Hisense 65" H9 Plus 4k HDR
https://linustechtips.com/topic/982403-fan/#findComment-11850140
Never mind I just looked at your spec's, download AI suit 3 I love it, on mine since I have two loops and one is not controlled because of the massive surface area I just bought low RPM fans ran @ full, However the rad fans in the case I have tied to the GPU temp this program easily allows all that control and setting up personalized fan curves are a breeze.
https://www.asus.com/Motherboards/ROG-CROSSHAIR-VI-HERO/HelpDesk_Download/
select your OS and then under utilities download ASUS AI Suite 3 or Dual Intelligent Processors 5 not sure the difference downloaded both and they are the same exact thing from what I can see.
https://linustechtips.com/topic/982403-fan/#findComment-11850338
