6 minutes ago, Hsjx said:
Tired pressing the power button, pc won't turn on(power on. CPU fan won't even start to spin). Tested psu with paper clip method fun spun up. What to do next?
Intel i5 7400
GTX 1050
maybe reconnect the power pins? might be plugged in the wrong way. had that once too
https://linustechtips.com/topic/981738-pc-wont-receive-power/#findComment-11843746
41 minutes ago, LukeSavenije said:
not the pins i meant, i meant the one which connect the power button, reset button, hard disk light, things like that
No idea how to check that. My pc is a pre made one that I just upgraded. Generic motherboard to. No idea where in the world is the reset switch
https://linustechtips.com/topic/981738-pc-wont-receive-power/#findComment-11843805
