Can i just replaced my thermal pads but one of the dram is half covered by the heatsink. and the rest with only thermal pads. Would this do anything bad in terms of temp?
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/981592-dram-cooling/
it's fine. DRAM chips dont get that hot without cooling and it's most likely like that when it left the factory.
or you flipped the heatsink the other way around, which isnt that easy to do.
Desktop benching:
https://linustechtips.com/topic/981592-dram-cooling/#findComment-11842257
Seeing in how there are cards with zero cooling on the ram and do just fine, don’t see how this is gonna be an issue. Just go with it.
https://linustechtips.com/topic/981592-dram-cooling/#findComment-11842601
