hello, i have recently put my pc in a new case and i was hoping that you could give me suggestions on how to hide front panel wires as seen in the picture (sorry bout the reflections, didnt want to remove panel)
Have a nice day:)
PC:    CPU: Core i7 4790k   I   GPU: MSI GTX 1070Ti Armor   I   COOLING: Custom water loop (cpu and gpu)  I  RAM: 16Gb DDR3 1600MHz   I   SSD: Samsung 850 evo 500Gb   I   HDD: WD blue 1TB, Hitatchi 2TB, Generic 1TB   I   PSU: EVGA 500w
https://linustechtips.com/topic/981513-cable-management/
kinda both tbh
Have a nice day:)
https://linustechtips.com/topic/981513-cable-management/#findComment-11841411
12 minutes ago, Ic3d said:
kinda both tbh
I mean the same logic still applies. Unfortunately there's no good way to hide them since they're very exposed, and you've done about as good as you possibly can to get them to not be a rat's nest.
https://linustechtips.com/topic/981513-cable-management/#findComment-11841439
2 hours ago, Ic3d said:
kinda both tbh
combine the front io cables together with some black electrical tape, that'll look a little better. I used electrical tape on a sata cable cause one of them was red instead of black and that bothered me
buy one of these for the GPU. it'll look a lot neater.
https://www.amazon.com/CableMod-ModFlex-6-pin-Extension-Black/dp/B077QR22FC/ref=sr_1_3?ie=UTF8&qid=1539203097&sr=8-3&keywords=cablemod+6+pin
https://linustechtips.com/topic/981513-cable-management/#findComment-11841838
Have a nice day:)
https://linustechtips.com/topic/981513-cable-management/#findComment-11844269
