Hey!
I am looking to move my NAS, thing, server, (idk really at the moment) into a room without an ethernet port. What is the cheapest possible solution to adding an ethernet port without breaking our lease agreement?
 Budget - $50 AUD
Weather it be powerline or an extender it HAS to have an ethernet out!
Thanks in advance!
My Machines:
I know. I need to update this. And I will. Eventually.
https://linustechtips.com/topic/981347-ethernet-solution/
just run a cat5 cable from your room to that room.
https://linustechtips.com/topic/981347-ethernet-solution/#findComment-11839943
CAT5e, or CAT6 would do nicely, yes. Not regular CAT5.
37 minutes ago, Snotrap said:
Hey!
 Budget - $35 AUD
Thanks in advance!
I run a setup with a range extender connected to a switch connected to 3 servers, so I can confirm that works alright. Performance isn't great, but it's adequate. Not going to work with just $35 though.
EDIT: I run a RE450, AC1750 based extender with gigabit capability. I average 50-60MB/s over the network with that over a distance of ~5-7m purely over 5GHz.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/981347-ethernet-solution/#findComment-11839952
1 minute ago, Snotrap said:
I wish. But. Females :/
Won't allow it.
I cant think of anything else that can be done with $35
https://linustechtips.com/topic/981347-ethernet-solution/#findComment-11839955
How about $50?
My Machines:
https://linustechtips.com/topic/981347-ethernet-solution/#findComment-11839961
4 minutes ago, Snotrap said:
How about $50?
cheapest powerline adapter I see on amazon.com.au is $70 and its only up to 500megabits.
https://linustechtips.com/topic/981347-ethernet-solution/#findComment-11839968
5 minutes ago, Snotrap said:
RIP. just 300Mbps wireless and just 10/100 ethernet. You must like network transfers of 10MB/s or less.
https://linustechtips.com/topic/981347-ethernet-solution/#findComment-11840017
On ‎10‎/‎11‎/‎2018 at 1:12 AM, beersykins said:
A nas on a range extender will perform like crap unless you can disable the WiFi repeating portion of it.
Its not a full blown nas.
Just use it to store files for game servers etc so I can remote in and start/edit them.
My Machines:
https://linustechtips.com/topic/981347-ethernet-solution/#findComment-11847028
I'd have to say you jumped the gun here as if its a proper PC based NAS you could probably have just used an 802.11ac PCIe card and gotten WAY better performance.
You didn't even mention you HAD WiFi, let alone what speed it was.
https://linustechtips.com/topic/981347-ethernet-solution/#findComment-11847277
