Hi,
I just ordered the parts for my new pc and got the idea that I might wanne use a DualShock controller. I've read that for it to connect wirelessly it need at least Bluetooth 2.0. The MB I ordered (the Gigabyte X470 Aorus Ultra Gaming) doesn't have BT but  have a M.2 slot left, so I thought I could use a M.2 wifi card. The card of choise and kinda the only option turned out to be the Intel Wireless-AC 8265.
After a bit of research I concluded that I have following problems:
#1: the card uses the A+E-Key but the Slot on the MB is a M-key
#2: the card has the 2230 format but the MB only supports formats greater or equal to 2243
Other option to get BT would be to use an BT USB-Adapter or a PCIe-Card. I'd like to avoid USB because it takes up an USB-Slot. Also I'd like to avoid PCIe because of the big antennas on the back.
The reason I'm trying for M.2 is that everything stays inside the case and it's relatively small.
The real question why I came here is to ask if you know of any adapter out there that converts M.2 2230 A- or E-key to M.2 2243 or 2280 M-Key.
And I kinda wanne know if my idea would even work.
Greatings
DarkHawk
https://linustechtips.com/topic/981204-intel-wireless-ac-and-m2-adapter/
My main piece of advice right now is avoid anything related to the Intel AC3160, because that dated chip and others from that  era don't play well with BT and Windows 10
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
9 minutes ago, DarkHawk said:
Hi,
Greatings
DarkHawk
Either way you will need antenna's for any non-usb card. I'd highly recommend a pcie one myself based on something no older than the 7265.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
