Well, so in that case the only I can say is that your computer "is making a fade-in and a fade-out kinda fan noise". It's normal after some time when you're using stock intel cooler (noise like wind going up and down), but you have "trusted one" fan, so it should be something else you don't trust. :)
Just stop one fan at the time when computer is powered on and you'll find which one is making funny noises.
https://linustechtips.com/topic/981145-weird-noise/#findComment-11837865
yes, iam using a stock intel, is that the problem? i only i got 2 fans 1 in 1 out, both same brand, a stock Intel cooler and a MSI 1050 ti (a sort of red one, couldn't find it on the net, so i think it is some sort of codex edition)
Edited by DraaiStoel
https://linustechtips.com/topic/981145-weird-noise/#findComment-11837869
2 minutes ago, BOTVladimir said:
But for the fan issue just go into your case and stop a fan by fan until you find the one that's making the noise. Just like homeap5 said.
yeah... its none
already tried some things
now that i think of it, couldn't it be one of my early stages of SATA HDD's?
https://linustechtips.com/topic/981145-weird-noise/#findComment-11837955
1 minute ago, BOTVladimir said:
Yep, It downloaded now. But that sound you don't have to be worried about it if we are talking about the same sound it's just your hard drive or fan spinning up. Nothing to be worried about.
hmm, don't want to be a dick, but its gone now, like what? might've been since just quit playing shadow warrior 2, but even then, *while* playing there was not fade sound
https://linustechtips.com/topic/981145-weird-noise/#findComment-11838031
