Hello everyone. I bought R5 2600 and Asrock TAICHI X470.
I have problem with temps.
https://imgur.com/a/USealS4 - sensor problem?!
Before I have box cooler but temperatures was so..dangerous. I think that my Cryorig H7 should keep Ryzen at 4Ghz below 80C.. but CPU is HOT. Cryorig is COLD. Stress test is crash.
Interesting one thing: In single channel RAM I have better temperatures:
https://imgur.com/aA0tSYv
I don't know.. Did this is problem with RAM.. with MOBO? or maybe COOLER? Asrock TAICHI looks solid ❤️ but I think sensor is broken. They can fix this in new bios ?! I don't think so.
I set in Bios debug led sensor cpu temp: It shows only 33C..all the time
CPU COOLER:    CRYORIG H7
RAM:                    HyperX 16GB 2400MHz Savage Black CL12
PSU:                    SeaSonic Focus Plus Gold 550W
CPU:                  R5 2600
MOBO:               ASROCK X470 TAICHI
https://linustechtips.com/topic/981020-asrock-x470-taichi-sensor-problem/
Cooler and thermal paste the were changes few times. I tried BOX and CRYORIG with CP7 paste and BeQuiet DC1.
In games I have pretty temps. But usage is around 40%. Stress test is a problem(I want make little OC but stable..)  I see that sensors shows different values.
Maybe this is bug CPU SENSOR? I can only monitoring tctl temperature and fans work only with tctl value.
It looks like it's that Corsair software.  If you need to confirm your CPU temps use Ryzen Master.  HWiNFO is also almost always correct from what I've seen, but use Ryzen Master to confirm against if you have doubts.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
I have a problem with sensor I think.. I use Corsair software because I want to find more INFO about sensors and temps. Corsair show me "package" - maybe this is broken sensor CPU ? Maybe this is a same sensor which show me all the time 33 on board led (read from sensor CPU)
