First build hopefully by March
So I'm building my first pc and I need some help just wanna see suggestions and and I'm new to forums but Linus is awesome  :lol:
Build >>> http://pcpartpicker.com/user/Pallex/saved/3lu8
- Pallaix (aka Chris)
And should i get 8 or 16gb of ram because i want to stream and game on pc and record?
https://linustechtips.com/topic/98094-need-help-with-first-rig/
all looks good but you could change a few things up
Edited by EvilLemur
Please Quote so i know you have replied. | If we have provided a solution to your problem mark it with answer found.
And also please read the COC and avoid the embarrassment and lecture that will ensue.
https://linustechtips.com/topic/98094-need-help-with-first-rig/#findComment-1312160
Build >>> http://pcpartpicker.com/p/2tyhb
interesting, i would see if u can get cheaper ram from kingston or gskill and try and get an SSD or a better HDD like a caviar black from WD, which would increase performance :)
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/98094-need-help-with-first-rig/#findComment-1312161
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($229.99 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.98 @ OutletPC)
Motherboard: ASRock Z87 Extreme3 ATX LGA1150 Motherboard  ($114.99 @ Microcenter)
Memory: Mushkin Silverline 12GB (3 x 4GB) DDR3-1333 Memory  ($109.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.98 @ OutletPC)
Video Card: Asus Radeon R9 280X 3GB Video Card  ($414.98 @ SuperBiiz)
Case: NZXT Phantom 410 (Black) ATX Mid Tower Case  ($85.98 @ Amazon)
Power Supply: SeaSonic 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($100.98 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.98 @ OutletPC)
Total: $1166.85
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-01-05 09:04 EST-0500)
https://linustechtips.com/topic/98094-need-help-with-first-rig/#findComment-1312236
basically when a component is slowing down another because its not powerful enough
 it dosent nessersarly mean slowing down just not leting it preform its best! thats how i like to think of it
taking some thing big and power full and trying to push it down in to some thing smaller and less power full
but i stil dont think "bottelneck" is a good word for explaneing a problem that can be caused by meany difrent things :)
https://linustechtips.com/topic/98094-need-help-with-first-rig/#findComment-1312293
@Pallaix
OEM stands for Original Equipment Manufacturer
Basically it means once you install the OS on that computer it can't be installed on another computer (usually tied to the motherboard or CPU)
Although I have completely changed computers and everything was fine... but ignore that lol.
If you want to install that same OS on a new computer (when old computer is too old or whatever) you may have to call up microsoft and tell them that you had to replace your motherboard because it broke etc etc and you need the key to be activated again.
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/98094-need-help-with-first-rig/#findComment-1312380
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  ($149.99 @ SuperBiiz)
Motherboard:  Asus M5A99X EVO R2.0 ATX AM3+ Motherboard  ($114.98 @ SuperBiiz)
Memory:  Team Vulcan 16GB (2 x 8GB) DDR3-1600 Memory  ($119.99 @ Newegg)
Storage:  Samsung 840 EVO 120GB 2.5" Solid State Disk  ($99.92 @ OutletPC)
Video Card:  Asus Radeon R9 280X 3GB Video Card  ($339.99 @ B&H)
Operating System:  Microsoft Windows 8.1 - OEM (64-bit)  ($94.98 @ OutletPC)
Total: $1170.80
(Generated by PCPartPicker 2014-01-05 09:51 EST-0500)
don't get the i5, you will need the 8320 when wou'll be streaming
if you like the price, get it :)
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/98094-need-help-with-first-rig/#findComment-1312441
planning on getting a 240mm all in one afterwards
You need to quote a post or tag a member or else they won't get a notification you replied to them.
Also, read before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
Don't plan until march. A lot of things may change by then.
^What he said
https://linustechtips.com/topic/98094-need-help-with-first-rig/#findComment-1316812
