i was thinking about getting a couple of thin client pc's but was concerned about there prossecing power
the one im looking at a hp T5135 with VIA Eden 400 MHz and 128mb ddr sdram cause i want to use this like a desktop and maybe play games
processing power is a concern so i was wondering if the client did all its processing from the host ?
https://linustechtips.com/topic/980928-thin-client-use-hosts-processing-power/
How are you setting up the thin client? What is the host setup?
These thin clients are often locket to one enviroment(citrix, horizon) and you need a expensive server setup to use it.
The client cpu won't be used at all, its all on the host.
The thing is that thin clients were never designed for gaming purposes or for any purpose where extremely low latency is a must. Plus those things were designed to be used with Windows Server 2000/2003, etc. Doubt you can get it to work with anything modern.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
i have an acer altos r520 server with 32gb ram running win 12 data center
i saw a youtube video by eli the computer guy using active directory and DNS
yeah if i cant game its alright its, its more of a test
problem is not all thin clients work with all servers, and most don't seem to work with win server.
Looking around you seem to need citrix here, and that won't be cheap
okay hmm
thanks for the heads up
