Hi all, would love some feedback on a new build idea.
Found what i think is a very good, reasonably priced case.
PC would be on all day and mostly used for internet, office use, streaming and photoshop. thoughts please.
SPEC
  • CPU - Intel - Core i5-8600 3.1GHz 6-Core Processor
  • CPU Cooler - Cryorig C7 CU
  • Case - Geek A50 MINI-ITX CASE
  • Motherboard - Asus - ROG Strix Z370-I Gaming Mini ITX LGA1151 Motherboard
  • Memory - Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory
  • Storage - Samsung - 970 Evo 500GB M.2-2280 Solid State Drive
  • PSU - Corsair - SF 450W 80+ Gold Certified Fully-Modular SFX Power Supply
  • Case Fans - 3x Noctua NF-A9x14 PWM Slim 92mm
  • Graphics- onboard.
https://linustechtips.com/topic/979485-advice-on-mini-itx-build/
20 minutes ago, BabyPCMR said:
Not sure about getting a z370 board with a cpu you can't overclock, might want to take a step down on the board and get an 8700 non K instead.
ASRock - Z370M
https://uk.pcpartpicker.com/product/7HYWGX/asrock-z370m-itxac-mini-itx-lga1151-motherboard-z370m-itxac
On 10/5/2018 at 8:16 AM, decimusbell said:
I meant get an H370 or B360 motherboard rather than a z370 beause you aren't getting a cpu that can be overclocked so there is no need for z370. You might also want to look into RAM that's rated at 2666 rather than 3200. Save money on those two components and put the extra funds into something that you'll actually notice like moving up from the i5 8600 you're going to get and get an i7 8700 instead. To me that would seem like the better move.
Or you could just get the 8600k because its the same price if not often cheaper right now.
https://pcpartpicker.com/products/compare/Mr2rxr,XMTPxr/
Rest In Peace my old signature...                  September 11th 2018 ~ December 26th 2018
Use an H370 motherboard to save a bit, Asus ROG Strix H370-I Gaming.
Locked Coffee Lake i5 like the i5-8600 will not run memory above DDR4-2666. A kit like Team - Vulcan 16GB (2 x 8GB) DDR4-2666 Memory would be fine. For slightly better performance use a kit like Kingston - 16GB (2 x 8GB) DDR4-2666 Memory.
A build log for the case would be nice.
11 hours ago, BabyPCMR said:
I don't see the point of getting an unlocked processor in that case
Except that it's sometimes cheaper than the locked version...
