Hello LTT forum this is my first post and I just want to get your guys help or advice on building a PC this will be the first build I'm just looking to do some gaming and some video production and I have made this following list on PCPartPicker in total the whole build is
$2012.22 USD because of rebates and all that jazz if you guys give tips or suggestions that would be appreciated thanks.
CPU-Intel - Core i7-8700K 3.7GHz 6-Core Processor-
$399.99
CPU Cooler-
Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
$37.89
Motherboard-
MSI - Z370 GAMING PLUS ATX LGA1151 Motherboard
$119.99
Memory-
G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory
$158.90
Storage-
Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
$58.89
Video card-Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G Video Card -
$699.99
Case-
NZXT - S340 (White) ATX Mid Tower Case
$70.46
Power supply-
Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply
$59.99
OS-
Microsoft - Windows 10 Home OEM 64-bit
$104.89
Monitor-
HP - OMEN 25 24.5" 1920x1080 144Hz Monitor
$268.90
Keyboard-
Corsair - K55 RGB Wired Gaming Keyboard
$45.25
https://linustechtips.com/topic/979172-first-pc-build/
$399.99
CPU Cooler-
$37.89
Motherboard-
$119.99
Memory-
$158.90
Storage-
$58.89
$699.99
Case-
$70.46
Power supply-
$59.99
OS-
$104.89
Monitor-
$268.90
Keyboard-
$45.25
Build this instead....
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($400.98 @ Newegg Business)
CPU Cooler: be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler  ($84.99 @ SuperBiiz)
Motherboard: Gigabyte - Z370 AORUS GAMING WIFI (rev. 1.0) ATX LGA1151 Motherboard  ($133.98 @ Newegg)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($119.99 @ Newegg)
Storage: ADATA - Ultimate SU650 480GB 2.5" Solid State Drive  ($68.89 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($58.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB AORUS Video Card  ($669.99 @ Newegg Business)
Case: NZXT - H500 (Black) ATX Mid Tower Case  ($61.00 @ Amazon)
Power Supply: EVGA - SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($56.08 @ B&H)
Monitor: Samsung - LC27JG50QQNZA 27.0" 2560x1440 144Hz Monitor  ($329.99 @ Amazon)
Total: $1984.78
Generated by PCPartPicker 2018-10-04 09:49 EDT-0400
https://linustechtips.com/topic/979172-first-pc-build/#findComment-11819721
2 minutes ago, DVA said:
I would honestly recommend a SSD and a better cooler.
An SSD is a must, like @DVA said, it helps windown boot much faster and programs will run faster when installed on it too. DVA was also right. A hyper 212 evo is probably a little too cheap for an 8700k, maybe go with a be quiet! brand cooler
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/979172-first-pc-build/#findComment-11819742
heres a build I tried to keep closer to your original, I just added the ssd, cooler, and changed some other things you'll spot
The build is about $78 more from the SSD, but an SSD is worth the money. It is 2124 also because I chose a little bit better of a motherboard. I don't hate MSI but sometimes their products can have the "gamer" marketing thing. If you want to change back feel free
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/979172-first-pc-build/#findComment-11819772
try this:
CPU Cooler: Reeven - Justice 82.1 CFM Sleeve Bearing CPU Cooler  ($46.89 @ OutletPC)
Motherboard: MSI - Z370 SLI PLUS ATX LGA1151 Motherboard  ($124.99 @ B&H)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($57.99 @ Newegg)
Storage: Samsung - 860 Evo 500GB 2.5" Solid State Drive  ($87.99 @ Amazon)
Video Card: MSI - GeForce GTX 1080 Ti 11GB GAMING Video Card  ($699.99 @ Newegg)
Case: Corsair - Carbide Series 275R Tempered Glass Newegg Edition ATX Mid Tower Case  ($69.98 @ Newegg)
Power Supply: Antec - Earthwatts Gold Pro 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($68.62 @ Amazon)
Monitor: AOC - AG241QX 23.8" 2560x1440 144Hz Monitor  ($259.99 @ Walmart)
Keyboard: Gigabyte - FORCE K83 Wired Standard Keyboard  ($39.11 @ Amazon)
Total: $1973.41
Generated by PCPartPicker 2018-10-04 10:13 EDT-0400
you can get os from reddit for $25.
https://linustechtips.com/topic/979172-first-pc-build/#findComment-11819778
I would move the Gigabyte gpu to the MSI one if they're the same price. Gigabyte is not bad, but MSI is just better. Gigabytes tend to run a little warmer and have been known to make a little bit of noise, which won't harm anything, but it's still there.
If you're going with air cooling, I suggest something like Noctua's fans. They're chocolate brown but are extremely reliable.
If you're interested in an AIO you can get one of Corsairs. Such as the H115i or H100 V2. They require very minimal to no maintenance and in some cases by the time it needs some maintenance it is time to upgrade your system anyway.
https://linustechtips.com/topic/979172-first-pc-build/#findComment-11819792
