Crossfire cooling questions
Go to solution Solved by bradscoolio,
No, but get a single card, like a 780, 290
2 270x's is cheaper than a 290x and will give you a better hash rate if you're mining. So it's not a bad choice
I already have one 270x so i can't afford to put out 400+ for another graphics card.
It's kewl dawg! You won't need any more cooling than that, you could get away with a lot less if you had to.
Just make sure they're not pressed up against each other, that they have at least 1 spare pci lane between them for airflow :)
Hey, I'm planning on running two Asus R9 270X gpus in crossfire on a Gigabyte GA-990fxa UD3 mobo in a Bitfenix Ghost case. I have two  AF120mm fans in the front, and one 120mm fan on the bottom for intake. and two SP120mm puling through a radiator and another 120mm out the back running as exhaust. My question is will I need to invest in more cooling if i run thes two cards in crossfire?
AMD diehard & Nvidia Enthusiest
https://linustechtips.com/topic/97906-crossfire-cooling-questions/
i would say to do it, but radeon cards are so damn expensive now, it would be better to sell it and buy another card
AAAAAAAAAGGGGGGGHHHHH!!!!
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
You will be fine .Plenty of cooling going on in your case.Just remember the top card will run warmer than the bottom card.When i ran my 7970 Ghz Editions in X-fire the top card ran @ 80c while the bottom ran at 65c under full load.
CM Storm Trooper| Asua Maximum VII Formula| 4770k H100i|Kingston Beast 32GB|Samsung Evo 250GB SSD|Seagate 3TB|EVGA Kingpin Edition 780 Ti(SLI)|Sound Blaster Z|Corsair 1200i
Samsung U28D590D | Corsair K70 | Razer Naga Hex | Kingston Hyper X Gaming Headset
