Clicky fans
Go to solution Solved by Fasauceome,
I returned to my PC and woke it up, the sound is no longer happening (even though I know which fan is the offending unit)
Oh well i guess, I'll get more in depth with the fix if it comes up again.
Slept my PC yesterday, turned it on today and was greeted by a rhythmic click of one of my Thermaltake Riing fans up against the front panel of my Vengeance C70 case. I took the panel off to see if there was any obvious obstruction, but I didn't see any blockage. I have noticed my fans seem a little wobbly, but I thought that was perhaps just a slight imperfection in the manufacturing. How long can I expect riing fans to last, and how could I know if mine need replacing?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/978804-clicky-fans/
fans with defects can last for years, but take that comment with a big grain of salt since it is entirely random how long it will last.
if you want to be sure and worry free. just get a new one.
but  my guess is that it could last a good bit, but i personally wouldn't dare it... i have the same with my corsair fan and im gonna replace it as soon as possible.
(just spent everything on pc parts so... yeah next month new fans :P)
Current build: Ryzen 7 1700x, asus prime x370-pro, 16gb gskill trident z rgb, asus rog strix gtx 1070 ti, corsair rm650x, nzxt s340 elite, samsung 840 pro 256gb, 1.5tb hdd.
https://linustechtips.com/topic/978804-clicky-fans/#findComment-11815932
Did you try doing a full shutdown and restart? Try a different fan header? Sometimes the power going into it will cause this.
https://linustechtips.com/topic/978804-clicky-fans/#findComment-11815939
With those fans, according to a retial website, they have a self lubricating system for the fan to stop it from making a noise/ceasing.
You've not seen any leakage in your PC have you?
Other than that, there is no wires hitting the fan or anything like that?
Current Build:
CPU: AMD Ryzen 5 2600 // Mobo: Ryzen AM4 B350 GAMING PLUS ATX // RAM: 16GB Corsair Vengeance LPX DDR4 3000MHz // GPU: Gigabyte AMD Radeon RX 580 Gaming 8GB // SSD: Kingston A400 120GB // HDD: 3 x WD Blue 1TB // PSUCorsair 650M // Case: Corsair 450D // Monitor: LG Ultrawide 29" IPS
Plex Server:
CPU: AMD FX 8350 Black Edition // Mobo: Gigabyte - GA-78LMT-USB3 R2 Micro ATX // RAM: 16GB Corsair Vengeance DDR3 1600 MHz // GPU: GeForce GTX 670 // HDD: Seagate BarraCuda 2TB // PSU: Kolink Core Series 500W 80 Plus Certified // Case: AVP Viper Mini Tower
Other:
PS4 Pro // PS3 // Nintendo Switch (Pokemon edition) // Nintendo 3DS // Xbox 360 // iPhone 8 Plus // Macbook Retina 2013
https://linustechtips.com/topic/978804-clicky-fans/#findComment-11815944
That's quite odd since removing the front panel removed the clicking sound. I don't think it's a power thing.
Primary PC:
PSU tier list
https://linustechtips.com/topic/978804-clicky-fans/#findComment-11815951
1 minute ago, Rhyss said:
With those fans, according to the manufacturers website, they have some weird self lubricating system for the fan to stop it from making a noise/ceasing.
Definitely no wires. I'm certain it's hitting the front panel, because when I remove the panel while the fan is spinning, the noise stops.
Primary PC:
PSU tier list
https://linustechtips.com/topic/978804-clicky-fans/#findComment-11815959
Either the fans not screwed down all the way or bad case design.
https://linustechtips.com/topic/978804-clicky-fans/#findComment-11815966
or the fan got some play in the bearing and starts wobbeling at low rpm's it happens, happened to me aswell wih a fan
https://linustechtips.com/topic/978804-clicky-fans/#findComment-11815971
Windows7ge could be right, try re-seating the screws and see if that helps. See if there is any case damage around where the fan is, could have been dented. If so you could work it back to the state it was originally.
Also see if the rubber anti-vibrate pads are still all in tact, if they're worn down for whatever reason it could be causing it.
Current Build:
Plex Server:
Other:
https://linustechtips.com/topic/978804-clicky-fans/#findComment-11815997
Check and make sure that the front filter is correctly slotted into the tabs and isn't warped in a way that makes it hit the fan blades.
https://linustechtips.com/topic/978804-clicky-fans/#findComment-11816426
Primary PC:
PSU tier list
https://linustechtips.com/topic/978804-clicky-fans/#findComment-11816838
