Will it bottleneck
Go to solution Solved by NunoLava1998,
5 minutes ago, XrayZ52 said:
I'm planning to upgrade from GT 1030 to GTX 1050Ti will it bottleneck the i3-2120 3.30Ghz DDR3 1333mhz with 600W PSU
It will bottleneck it a fair amount. A i5-2320 is probably cheap as hell on eBay and will work great with the GPU.
Idk what that i3 wouldn't bottleneck, I think even that 1030 is struggling. How about an i5 first, that ought to be a much better performer. (or an i7 because that generation of locked i7s are great budget CPUs)
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/978540-will-it-bottleneck/#findComment-11813184
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/978540-will-it-bottleneck/#findComment-11813196
12 minutes ago, XrayZ52 said:
I'm using a P8H61-MX USB3 motherboard it should work with i7-2600 with stock cooler
Yeah
Primary PC:
PSU tier list
https://linustechtips.com/topic/978540-will-it-bottleneck/#findComment-11813257
