The recently added feature where notifications pop up on the left side of the screen, how do you turn that off???
GIGA AORUSBYTE B550I PRO AX (AM4 AMD/B550/Mini-Itx/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 1/WiFi 6/2.5 GbE LAN/PCIe4.0/Realtek ALC1220-Vb/DisplayPort 1.4/2xHDMI 2.0B/RGB Fusion 2.0/DDR4/Gaming Motherboard) ,AMD Ryzen 7 5800X 8-core, 16-Thread Unlocked 4.7 GHz, TEAMGROUP T-Force Vulcan Z DDR4 32GB (2 x 16GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
https://linustechtips.com/topic/978429-facebook-help/
I still want to get them under the bell, just not pop up on the left side of the screen...
https://linustechtips.com/topic/978429-facebook-help/#findComment-11812131
8 minutes ago, PC_Master said:
@Edward78 You will still get a notification under the bell, but instead it will not show up on the left side of the screen
Sorry for the DUH facter, I can't find where to turn them off...
https://linustechtips.com/topic/978429-facebook-help/#findComment-11812162
If you're using chrome, click on the lock :)
Current Build:
CPU: AMD Ryzen 5 2600 // Mobo: Ryzen AM4 B350 GAMING PLUS ATX // RAM: 16GB Corsair Vengeance LPX DDR4 3000MHz // GPU: Gigabyte AMD Radeon RX 580 Gaming 8GB // SSD: Kingston A400 120GB // HDD: 3 x WD Blue 1TB // PSUCorsair 650M // Case: Corsair 450D // Monitor: LG Ultrawide 29" IPS
Plex Server:
CPU: AMD FX 8350 Black Edition // Mobo: Gigabyte - GA-78LMT-USB3 R2 Micro ATX // RAM: 16GB Corsair Vengeance DDR3 1600 MHz // GPU: GeForce GTX 670 // HDD: Seagate BarraCuda 2TB // PSU: Kolink Core Series 500W 80 Plus Certified // Case: AVP Viper Mini Tower
Other:
PS4 Pro // PS3 // Nintendo Switch (Pokemon edition) // Nintendo 3DS // Xbox 360 // iPhone 8 Plus // Macbook Retina 2013
https://linustechtips.com/topic/978429-facebook-help/#findComment-11812177
