RGB LED Stripes
Go to solution Solved by Underi,
The LED strip should be fine since the connector fits to the motherboard LED connector.
yes it should work but you may have to solder your own connector to the end of the LED strip.
It is technically compatible and just has the wrong connector.
also i couldn't find any info how many LED´s the connector on your mainboard supports and usually only higher end boards will support up to 300.
https://linustechtips.com/topic/977994-rgb-led-stripes/#findComment-11808163
My stuff:
CPU :  Intel i5 8400 | GPU : MSI GTX 970 Gaming 4GB
RAM : 32GB Corsair Vengeance DDR4 @ 3600MHz
Mouse : Logitech G502 HERO SE | Keyboard : Mountain Everest Max w/ Cherry MX Brown
Headset : Beyerdynamics DT990 Pro 250Ω w/ AT2020USB+
Monitor : Acer XF240H @  144Hz
https://linustechtips.com/topic/977994-rgb-led-stripes/#findComment-11808296
