PS4 controller with Xbox layout
Go to solution Solved by Stefan Payne,
9 minutes ago, IAmAndre said:
Hi,
I'm looking for PS4 controllers with the left joystick on top, just like on Xbox. I've seen a few on eBay but I want to know if there are some rather official/reliable ones and not cheap Chinese alternatives that might break quickly.
Thanks
There's a ton, though they are a bit higher end.
My tip would be to try the PS4 Controller for a couple of days before switching to a different one. Personally I find every controller weird that I haven't used for a longer period of time. You need a bit for a different one. If you still don't like it after a Week or so, you can buy one of those:
not (necessarily) wired:
https://geizhals.de/razer-raiju-tournament-edition-wireless-controller-pc-ps4-rz06-02610100-r3g1-a1874005.html?hloc=de
https://geizhals.de/hori-onyx-wireless-controller-ps4-a1755847.html?hloc=de
Wired:
https://geizhals.de/nacon-revolution-pro-2-controller-schwarz-ps4-a1679110.html?hloc=de https://geizhals.de/nacon-revolution-pro-controller-weiss-ps4-a1667267.html?hloc=de
Hi,
Thanks
Wired:
"Hell is full of good meanings, but Heaven is full of good works"
Wired:
Thanks a lot. I think I'll go for €45 one since it's actually cheaper than the original one and I'm quite familiar with the brand.
I just can't stand the official PS4 controller because of the layout but also because it feels so cheap and the gum on the stick is low quality do my thumb always slides on it, and the gum itself doesn't last long.
Öhm, you complain because the PS4 Controller feels cheap and want the cheaper controller? oO
There is something wrong with that logic. If you want the "feel good" stuff, you usually have to pay more because you can only do so much with a certain amount of money....
And you should, if possible, go to a store and "feel one" for yourself...
As for the Stic Quality: its not that bad, at least with the one I've gotten with my PS4 PRO, they just use rather hardish rubber, not the softer more grippier ones...
But I also have to say that there might be at least half a dozend or more different versions of the Pad, so our two Pads might not be the same and we might actually talk about totally different things.
I realized that when getting my second PS4 Controller wich feels rather different from the one that came with my PS4 PRO...
