So I want to change the voltage to my 4790k from my B43-G43 GAMING so I can increase my stability at higher frequencies. I've played with ring frequency (I understand I'm not hurting anything but I have no idea if I'm helping with stability). I'm pretty sure I'm on the wrong path with ring frequency though - just from what others have said.
Here's the meat of the question: which voltage option(s) do I modify? CPU core voltage? Do I also increase ring voltage? Voltage offset?
I'm not bluescreening or anything, just getting errors in WoW every now and again. I suspect a very small 8mV jump would probably do it but I'm not overly afraid to play around.
The purpose of this is to get better FPS in WoW and other games, because I've learned that the CPU is probably my FPS bottleneck (gtx 970 btw). Though even if I'm incorrect about that, I am enjoying myself and want those dank high temps. Before overclocking, I could never get my CPU over 70C. Which just seems...like a waste.
https://linustechtips.com/topic/977602-how-to-increase-cpu-voltage/
You want to change core voltage, there can be a CPU voltage too but that would be the voltage going into the CPU that's then converted in the FIVR. Raising VCC_IN/CPU voltage can help when really pushing overclocks, to get my I7 4790K to 5GHz I'm running 1.35V vcore and 2V VCC_IN. 45x on ring and a little extra voltage of set for it.
Builds:
VCC_IN = CPU voltage?
So let me get this straight. Voltage goes into CPU/VCC_IN which is then "spread" across the core as well as other components. Core Voltage allows higher frequencies. So Core Voltage is choked by VCC_IN and GHz is choked by "Core Voltage" also known as VCore.
Do I got that about right?
Also; thank you. I can only dream about your clock speeds.
not totally correct, Vccin = CPU input voltage is what's sent to the FIVR (fully integrated voltage regulator I believe), which is responsible for stepping down voltage to your Vcore = CPU core voltage which feeds into the CPU core. Vcore is what limits your core frequency.
Desktop benching:
Vccin fuels FIVR which chokes Vcore which chokes frequency.
Is the following statement correct in your opinion? "If any of these values is insufficient, a BSOD is the worst realistic consequence, outside of data loss from badness in data."
How about this one? "In theory, if Vcore were to be raised 100mV, best practice would be to raise Vccin by 100mV as well."
Do I got it about right? Not saying you said these things, just stating assumptions I'm making :)
