how storage works
Go to solution Solved by Pickles von Brine,
Pretty easy really. Get a program that can do a data erase. HDD Tune can do it. Mini Partition Wizard can as well. Then you can just use a hex editor to confirm the data is erased. There are a few free ones out there.
Hell, if you used dd in linux you can set it to do a zero pass on a drive and have it write zeros. There are many many many ways to do it.
BTW, best hex editor I have ever used was WinHex. However, it is complex and not easy to use. You kinda have to know how to use it. It also offers the ability to erase data too.
so i know that if you delete something it just shrinks down then is just overwritten after a while but, what about say if i moved it over to a removable drive/disk, is there any information that can be traced back to my computer and one more thing, when you reformat removable disk, does the files delete on the removable disk or does it move over to your device (for me my computer) then "delete"?
https://linustechtips.com/topic/977472-how-storage-works/
files are mearly made invisible to the os , they are mostly still there in their entirety until overwritten , they dont shrink down at all.
Same with a removable disk , the file is just made to look like empty space but until it's overwritten it's still pretty much there entirely , even reformatting will mostly just mark space as being empty but the files are still there,
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11803626
oh , as far as tracing information back to your machine. the file would have to be something specific to you or your machine
specific to you in that it's a picture or file that mentions you , or specific to your machine in that it's a file that mentions your machine like a bsod dump file that contains your pc configuration and someone could put two and two together that it's probably your machine. ect...
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11803641
2 minutes ago, emosun said:
files are mearly made invisible to the os , they are mostly still there in their entirety until overwritten , they they dont shrink down at all.
i was always told that they shrink down... but ok thats also understandable the main question i wanted answered was the removable drive one, so the "delete" data on the flash drive stays on the flash drive (i am not doing anything illegal just things i dont want people to know about) the 2ed main question is "is there a trace on oh program A was moved to a new drive"
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11803643
is there a way to get around that?
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11803646
so long as the file that is being moved/deleted has nothing to do with you specifically or mentions the pc being used to do it specifically then it could essentially be a file that was moved by any machine.
essentially the only thing that can be recovered from a drive that wasn't securely formated or deleted is the files themselves and the time they were moved or changed/accessed last.
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11803656
The only way to completely remove traces from a file is to overwrite free space with 0s with a tool like ccleaner or something else.
Moving or deleting files just removes the location, doesn't remove the actual data.
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11803669
Or overwrite with 0s then random data afterword. Best practice is a 7 pass with 0s then junk data and repeat. Even if I had the best possible software and technology available it would be almost impossible to recover data after being overwritten 7 times with 0s then junk data.
Be sure to @Pickles von Brine if you want me to see your reply!
Stopping by to praise the all mighty jar Lord pickles... * drinks from a chalice of holy pickle juice and tossed dill over shoulder* ~ @WarDance
3600x | NH-D15 Chromax Black | 32GB 3200MHz | ASUS KO RTX 3070 UnderVolted and UnderClocked | Gigabyte Aorus Elite AX X570S | Seasonic X760w | Phanteks Evolv X | 500GB WD_Black SN750 x2 | Sandisk Skyhawk 3.84TB SSD
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11804479
this may be a dumb question... when you say 0s do you mean operating system?
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11804500
I am not. If you where to look at a drive in a hex editor the raw values would all be "0"
Unlike this one which has data on it:
This one has no data and has been zeroed out:
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11804517
oh dang i never really play with raw data before, other then learning about it in my computer science class
so is there any tutorials on how to do this?
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11804528
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11804536
cool thanks
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11804539
Just now, Conan Wolf said:
cool thanks
Anyime. If you got a question and I can answer I will gladly supply it to you.
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11804542
Agreed I'd just add the file simply has a piece of information like a key or a code that marks it as deleted to the OS. This is done as it greatly speeds up the process of deleting a file as to actually delete a file from disk takes quite a bit of time.
There are 10 types of people in the world: those who understand binary numbers and those who don’t
bulgara, oh nono
Multipass
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11804546
That it does. Better to mark it for overwrite then spend 20 minutes deleting the file especailly if it is several gigabytes in size.
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11804555
If you're really serious about keeping your data safe from prying eyes it's wise to power down your PC when you're not around as RAM contains a whole bunch of sensitive information such as users logged in along with the times they logged in, emails, and even crazy stuff like plaintext files along with their private encryption keys if your doing anything that is encrypted. Luckily RAM is volatile so when you remove power all the info is lost, if people can gain physical access to your computer they can create disk images of both your system memory and storage then techniques such as file carving can be used to hunt for personal or sensitive data. Obviously this would never happen to you unless you're secretly running an online drug market or something crazy like that which I'm sure you're not... right?
bulgara, oh nono
Multipass
https://linustechtips.com/topic/977472-how-storage-works/#findComment-11804579
